1. '96 Cherokee Cold Temp Start Issue
    This winter, my 1996 Cherokee Sport developed a cold temperature start problem. If overnight temps are below 50 degrees or so, the engine cranks just fine but without firing. If I pump the accelerator, while doing short cranking bursts, it eventually roars to life. Of course being fuel injected, I have no idea if the pedal pumping is really affecting the start. Sometimes after this type of start, the engine will not idle until it warms up. When temps are warmer, the cold engine always starts right up like normal. No vacuum leaks are apparent, and the Manifold Air Temp Sensor seem to check out as OK. Sound familiar to anyone?
    Feb 2009
    Dayton Ohio Area
    5,955
    Re: '96 Cherokee Cold Temp Start Issue
    Check fuel pressure key on and off and while it is running. Should be constant.
    Check spark to the plugs.
    After a year with the problem getting worse, and replacing plugs, wires, cap, and rotor, and noting fuel pressure irregularities, I replaced the ECU. Fixed!
    Feb 2009
    Dayton Ohio Area
    5,955
    Glad to hear you repaired it.
    Thanks for checking back on this . . . however . . I think the timing chain just broke. I'm almost to the chain, and should get the cover off tomorrow. Do you, by chance, know if this 4.0 inline 6 is an "interference" engine? At 265,000 miles, I'm not likely to tear the motor down to check for damage. Thanks, again. TJ
    Feb 2009
    Dayton Ohio Area
    5,955
    I do not believe it is an interference engine.
    Also these chains stretch but do not normally break. The engines have been known to go 500k mi with no chain issues. Pics if it did.
  7. #7
    Thanks. I'll post a picture if it's broken.
  1. Transmission over temp issue...is back again, help?
    By laredo2006 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-27-2015, 09:13 PM
  2. cold start
    By j gonzalez in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-29-2015, 01:31 AM
  3. 98 Wrangler (Trans issue when Cold)
    By my98jeep1970 in forum Wrangler and CJ
    Last Post: 12-11-2013, 03:50 PM
  4. Cherokee cold start, chocking problem
    By deesweet in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-20-2007, 02:51 PM
  5. Cold second start?
    By Kevin72 in forum Cherokee, Commander, Wagoneer and Liberty
