Mud junkie
i have a 1193 Jeep Cherokee as I mentioned in other conversations, building for just mud bogging.
My question is if anyone could give me just the basic wiring I need to start it and run, I want to eliminate as much of the wiring as possible. I have all the wiring diagrams and I'm sure I could figure out, but I was just hoping someone has done it. I have no problem building new relay and fuse box if needed.
thank you in advance for any help or comments that might help.
Wow thats old.
What engine? Fuel injected?
You will need battery, alternator, pcm, ignition, ign wires, cps, ckp,
To avoid rough running temp sensors, and O2 sensors.
You will need fuel pump and possibly the nss
