11-22-2021, 01:29 AM #1
1996 Jeep Cherokee Max Flex Stock
Hello, Im new to this forum and would like some advice on getting the maximum flex out of a XJ while maintaining stock or very close to stock ride height. The way I'm building my Cherokee is a very practical overall vehicle for onroad and off-road application, which means I will be running stock 235/75/R15 tires and factory axle gear ratios. The plan is to overland this XJ eventually, and would like to be very capable on trails, not making a rock crawler here. What I think im gonna do is obviously start with the sway bars, remove the rear and add a disconnect for the front. I was thinking about getting HD leaf springs for the rear for a 1" lift and spacers for the front? I don't know if the stiffer leafs would hinder flex or not but my current ones are sagging so they need replaced ideally. One thing I did think about is a long arm kit, is this unnecessary for a stock spring? Any other suggestions would be appreciated. Thank you for reading, Lucas.
11-22-2021, 09:32 AM #2
There are quick releases for rear sway bars. I wouldnt drive around without the rear sway bar as a daily driver.
HD leafs will limit articulation.
You would benefit from long arms if you lift more than 3 inches.
Check that articulation is limited by the springs and not brake lines or shocks.
By stock do you mean a low center of gravity build?
Never look down on anyone unless you are helping them up - Jesse JacksonLast edited by JPNinPA; 11-22-2021 at 10:11 AM.
11-22-2021, 01:07 PM Thread Starter #3
Re: 1996 Jeep Cherokee Max Flex Stock
Alright, I'll get some rest disconnects then. Is there any better options to the factory leaf springs? If not I'll just buy brand new ones.
That's what I figured with it being stock ride height. Would like a low center of gravity but mainly I'm keeping it stock for gas mileage and I really like the idea of a stock Cherokee doing fantastic off-road. I'm not opposed to bigger tires and a lift if thats what I have to do to get decent articulation, but I personally just love the look of a stock Cherokee.Last edited by Lpardee96; 11-22-2021 at 01:53 PM.
11-22-2021, 07:47 PM #4
Look at ARB. Or Old Man Emu. OME.
They do lifts and have good ride characteristics.
Never look down on anyone unless you are helping them up - Jesse Jackson"Never look down on anybody unless you're helping him up" - Jesse Jackson
01-17-2022, 12:11 AM #5
A little late to the party, but you are right about the sway bars. As far as the springs/shocks well I hava an opinion. My 96 came with the Upcountry Suspension, but after 250k was replaced by the previous owner with the Amazon equivalent of an Upcountry that resulted in a 1 1/2 inch lift. I'm okay with it, but I've had the OME suspension on a CJ7 and a Land Rover and I plan on putting it on my XJ soon. The reason being it is an outstanding suspension with a small lift of 1 1/2 to 2 inches that rides beautifully on and off road. You can run your 235/75 15's or go slightly larger. I run 225/75 16 (29.3") but you can go slightly taller with your 3.55 gears and be happy. I switched to 16 inch Icon wheels off of 2000 Cherokee so I might go to 235/75 16 or a 245/75 16. I personally don't want to regear so I think a 30.5" is about the limit of tire diameter I'd be happy with. Hope this helps.
Locked radio (stock) on Jeep Grand Cherokee Limited 1996.
By zaczg in forum Jeep Electronics and AudioReplies: 6Last Post: 05-19-2011, 04:42 PM -
1996 Jeep gran cherokee larado
By joerope in forum Cherokee, Commander, Wagoneer and LibertyReplies: 3Last Post: 08-25-2009, 10:03 AM -
1996 Jeep Grand Cherokee
By armancha in forum Cherokee, Commander, Wagoneer and LibertyReplies: 6Last Post: 08-14-2008, 07:06 PM -
By cconner_1967 in forum General ChatReplies: 2Last Post: 08-14-2008, 07:00 PM
