Thread: 2008 GC Limited Popping noise
03-28-2023, 06:49 PM #1
Hello,
Anyone had an issue when making a turn with a popping noise(not a clicking noise). Sometimes its two or three consecutive pops. I have checked the CV joints but they look fine. No torn boots or leaks. Is there some other way to check them for looseness or issues? No vibrations.
Thanks for your time,
Chris
03-29-2023, 03:52 AM #2
Sway bar link
Ball joint
Twist and push on the shaft. There should be zero movement side to side.
Second test it to drive slow in a circle. Turn full to stop left then right. The bad CV will click fairly loud.
Never look down on anyone unless you are helping them up - Jesse JacksonLast edited by JPNinPA; 03-29-2023 at 07:40 AM.
03-31-2023, 12:14 PM #3
Re: 2008 GC Limited Popping noise
Do you have an auto locker diffetential? If so, it may be that.
94 yj popping noise
By overboard63 in forum Wrangler and CJReplies: 4Last Post: 10-07-2015, 06:01 AM -
popping noise
By jeepgirl33 in forum Cherokee, Commander, Wagoneer and LibertyReplies: 1Last Post: 02-22-2013, 08:47 AM -
popping noise
By firestarter in forum Cherokee, Commander, Wagoneer and LibertyReplies: 3Last Post: 08-14-2010, 09:44 PM -
popping noise when in 4x4
By drewbaby in forum Wrangler and CJReplies: 2Last Post: 01-29-2010, 12:49 AM -
Popping noise when shifting
By FloridaJeeper in forum Wrangler and CJReplies: 3Last Post: 07-13-2005, 12:06 AM
