barn smell from ac
1072501
There may be mold growing on the A/C evaporator coils. This will/can happen if the evaporator drian hose is clogged and water sits in there for some time. See if there is water dripping from under the passenger footwell area under the car while or after the A/C has been running.
Another possibility is that you are smelling an Antifreeze leak from the heater core. If there is any indication this is happening, don't run the ventilation system until the core is replaced (antifreeze is a major health hazard! :-O)
Good Luck
-Nick[addsig]
1072580
Nick has it pegged...one or the other..maybe both..mold is also a possible health risk. Even a leak in the heater core too small to leave much obvious evidence can leak enough to stink pretty bad, especially if you have a strong coolant solution.[addsig]
1074698
I have the same problem I have a 1995 ZJ and smells like barn. Does anyone know how dificult it would be to fix?[addsig]
1074699
i've also heard of small animals crawling up in there and dying...[addsig]
