Lower Control Arms
y2kxj
I have a 2000 xj with an OME 2-1/2" Lift(complete leafs, shocks etc.), removed rear sway bar and 255 BFG A/T's, I was wondering is there an advantage to going with after market lower control arms? Will this give me a longer suspension travel in the front end or should I go with quick discontects? I am looking for the best ride available, while still having an off road worthy machine. Any input is appreciated.
if you dont have quick disco's in the front end, i'd suggest it... makes a major difference (like 6" more flex on stock suspension)
Yes, get the disco's for the front. You should be fine with the stock LCA's with that much lift, look at longer ones if you experience any wobble.
