Does anyone know the length of a front drive shaft for.....
1042561
search around junkyards for a used one.
as for length i dont know[addsig]
1042587
Hi "jeep4wheelin."
In your posting you didn't mention if you had "command trac" or
a "selec-trac", the front driveshafts are different for each.
The "Command-Trac" is fitted with "single cardan u-joints."
The "Selec-Trac" is fitted with a "constant velocity style joint."
As far as the length--- not sure..but you will have one or the other
that I listed above.
----NEALSTER-----[addsig]
