99 jeep cherokee
dhcboys
My cherokee will start and idle when cold, will die when try to rev engine,and have to let sit for about 30 min. or so before it will start agian, i have replaced fuel pump and pressure regulator, did not help, thinking maybe clogged injectors, any help would be great!!!
if i remember right, a bad crank sensor can shut 'er down once it warms up. you throwing any codes???
Got it, the problem was the coolant temp. sensor, once warm would shot down fuel delivery!! Thanks for the help
