    v8only's Avatar
    v8only is offline Junior Member
    Apr 2009
    2
    code p0031 in a 2003 cherokee 4.0..Lost!!
    Hello, got code p0031 in the 03 2wd cherokee and have replaced #1 o2 sensore before the cat with two different dealer o2 sensors.
    the ecu has also been replaced.
    completely lost here. p0031 will NOT go away, and we can't get this thing through california smog.
    any ideas here?? Thanks all..Jeremy
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Re: code p0031 in a 2003 cherokee 4.0..Lost!!
    Cherokee or Grand Cherokee?. K1 Body (CKD) Cherokee or X2(China) Cherokee. I'm confused. Here are the possible causes for the P0031.
    O2 HEATER TEST
    O2 SENSOR HEATER ELEMENT
    (F142) FUSED ASD RELAY OUTPUT CIRCUIT OPEN
    HEATER CONTROL CIRCUIT OPEN
    HEATER CONTROL CIRCUIT SHORTED TO GROUND
    PCM
    TEFrom the looks of it , youv'e STBy the s
    FF
    F
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    From what the possible causes VS what you've already replaced, it looks like an electrical issue. Check the Fuses on the PDC first.
    v8only's Avatar
    Apr 2009
    2
    pdc? I assume you're talking about the primary fuses?
    It's a grand cherokee.
    I'll check all the fuses....Thanks!
  1. Grand Cherokee: Lost oil pressure/ Sloshing sound
    By Jake89 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-22-2008, 07:41 AM
  2. Rolling code on '96 Grand Cherokee Homelink
    By Timithing in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-06-2004, 09:21 PM
  3. code reader for 86 Cherokee
    By RAVEN13xxx in forum Cherokee, Commander, Wagoneer and Liberty
  4. 97 cherokee computer code: 45
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
  5. 85 Cherokee paint code verification??
    By vfrf2 in forum Cherokee, Commander, Wagoneer and Liberty
