1995 Cherokee temperature sensor
szuber
I have a 1995 4.0L. The last three times I have driven it (and it's hot here in LA) once I turn it off, the overflow at the radiator blasts fluid for about 10 seconds or so...emptying the overflow reservoir...I have added antifreeze water mox each time through the overflow (not directly into the radiator) and it just does it again. Took it to Pep Boys and they said that it didn't do it for them...they went ahead and replaced the temperature sensor ...which in ten minutes the NEW one went out on them...they have no idea what it could be and suggested I take it to the dealer or a Jeep specialist...The idiot light on the dash does not light when I turn the ignition to the start position either...I suppose this might be due to the bad temperature sensor?
Any Ideas?
