    mmurek's Avatar
    mmurek is offline Junior Member
    Aug 2009
    Western NY
    9
    Noob question of all noob questions, how do I shift gears?
    I have been the proud owner of a 2001 Cherokee Sport for about 24 hours now. I didn't get an owners manual with it and can't find a down loadable one anywhere. If anyone knows where I could find one let me know, I have already purchased a paper copy online waiting for delivery. To my question, I assume that shifting from 2WH to 4WH is shift on the fly, but what is the procedure to shift to 4WL? A 2004 Grand Cherokee manual recommends driving 2-4 MPH, shifting to neutral and then to low, is this correct? Thanks for any help.
    Mitch
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Re: Noob question of all noob questions, how do I shift gears?
    Shift the trans. to neutral and then shift the t-case to 4Low @ 2-4 like yo u've gathered. If you time it just right, by shifting the trans. to neutral, quickly shift the t-case to 4low while the gear cluster is still moving to complete the shift. This works too but it takes a little practice without grinding the gears.
    54cj3b's Avatar
    54cj3b is offline Senior Member
    Aug 2009
    Evergreen,Colorado
    1,520
    you should always come to a complete stop put gear shifter in neutral engage 4 low put back in gear and go shift on fly is only for 4 hi at 10 15 mph moving and shifting into 4 low can cause major transfer case damage and is not recommended
    take it from a certified jeep mechanic
    we wouldn't steer you wrong ,seen to many busted chains and gears in many cases in my day
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
    mmurek's Avatar
    Aug 2009
    Western NY
    9
    Thanks for the imfo! The manual says you can shift into 4H at up to 55 MPH, from your post I assume that is incorrect from your experience? Just want to be sure I understand you correctly. Thanks again!
    Mitch
  1. noob question
    By staquinas in forum CJ YJ TJ and JK
    Last Post: 07-07-2009, 06:19 PM
  2. Another 'noob' question
    By Jason4x4 in forum CJ YJ TJ and JK
    Last Post: 07-20-2006, 02:59 PM
  3. Not a Noob, but a Noob question:
    By Sparky-Watts in forum General Chat
    Last Post: 06-20-2004, 01:08 PM
  4. ima noob
    By chacha in forum General Chat
    Last Post: 10-31-2003, 07:01 PM
