    rdm7938's Avatar
    rdm7938 is offline Junior Member
    Aug 2009
    Albuquerque
    8
    HELP - 1996 Cherokee Sport
    Hi all... this is my first post on the forum and I'm hoping for some help/reassurance.
    I have a 1996 Jeep Cherokee Sport that was given to me by my Grandmother and therefore I have all maintenance records and know that it was a one owner vehicle (it is a manly shade of teal).
    I have been told that Jeeps last forever, but I have had nothing but problems. It started out as a engine/power "LULL" when I was driving where it would just kind of cut out before it would kick back in (highway, local streets, etc.). But, now it won't even start
    Previously (during the "Lull" period) I took it to a mechanic and replaced the following:
    $300 = New heater control valve, hoses, clamps, etc.
    $1100 = New head gasket, radiator, belts, thermostat, coolant flush, oil change, etc.
    Any suggestions on what it may be? Fuel pump? Could it be anything else?
    I'd rather not pump a whole lot more money into it, but I'm going back to school and don't need a car payment either. Thanks!
    superspud87's Avatar
    superspud87 is offline Member
    May 2009
    73
    Re: HELP - 1996 Cherokee Sport
    when you try to start it does it try to turn over? or does it just not do anything?
    rdm7938's Avatar
    Aug 2009
    Albuquerque
    8
    Absolutely nothing... the battery is live because the key reminder is buzzing, but the engine doesn't even try to turn over.
    54cj3b's Avatar
    54cj3b is offline Senior Member
    Aug 2009
    Evergreen,Colorado
    1,520
    most likely the cps
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Quote Originally Posted by rdm7938 View Post
    Just because the key minder is buzzing doesn't mean that the battery isn't bad specially if the engine won't even turn over. Check the battery connections and when in doubt, take the battery to a parts house that will check it for you for free. Start the process of elimination from the basics before you move on to the more indepth technical issues.
    rdm7938's Avatar
    Aug 2009
    Albuquerque
    8
    What about the previous lull in power... would that be the fuel pump beginning to go bad?
  7. #7
    carnuck's Avatar
    carnuck is offline Senior Member
    Jan 2009
    Seattle
    917
    Sounds like the mechanic may not have known what he was doing.
  8. #8
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Yes it's possible, however it could also be a flatspot on the TPS or like 54cj3b suggested a CPS(loose or corroded connection). You can check the fuel pressure at the fuel rail test port with a test gauge and see if its within specs at idle and while doing a WOT(wide open throttle). When was the last time the fuel filter has been replaced?, could be as simple as that but you need to do some test to get a sense of directon in isolating this concern.
  1. Cherokee driver's seat 1996
    By Zkema in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-13-2013, 10:17 PM
  2. 1996 Cherokee Sport 4.0 L 5-Speed 2-door
    By Forbin23 in forum Items for Sale, Trade, or Give Away
    Last Post: 12-19-2008, 05:31 PM
  3. 1996 Jeep Grand Cherokee
    By armancha in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-14-2008, 06:06 PM
  4. 1996 Cherokee XJ
    By dropseys in forum Items for Sale, Trade, or Give Away
    Last Post: 02-11-2006, 12:27 AM
  5. 1996 cherokee recalls????
    By AKASHAJEEP in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-15-2003, 08:54 AM
Tags for this Thread
