    cali_92's Avatar
    cali_92 is offline Senior Member
    Nov 2009
    California
    195
    04 grand cherokee special edition needs lift
    friend just got a 04 jeep grand cherokee special edition 8cyl. 4wd
    and turn to me and wants me to lift it. i've only done my jeep yj. but i kno doing coil springs is pretty easy. he's only looking for like a 2" lift to eliminate the tire rub on it, i havent seen it yet so i dont kno what the problem is and or tire size. im guessin 31.
    so suggestions on the lift.
    go easy budget boost spacer lift. (which im usually against on wranglers)
    or full suspention lift? and what brands. idk if rough country is a stiff for fran cherokees but for wrangler i kno they are.
    XJsport95's Avatar
    XJsport95 is offline Junior Member
    Feb 2011
    Michigan
    18
    Re: 04 grand cherokee special edition needs lift
    what kind of budget are you looking at?
    cali_92's Avatar
    Nov 2009
    California
    195
    dont have one in mind...
    a list would b nice if u have a couple of ideas.
    anything from cheap and simple
    to nice and takes a lil more money
    dustin g's Avatar
    dustin g is offline Senior Member
    Nov 2010
    Gilbert AZ
    314
    Rough country 4" x-flex kit. Around $850. Great lift for the price.
    If I Wanted A Hummer I Would Have Asked Your Sister!
    1998 Jeep Grand Cherokee Laredo 5.2L (Up-Country)
    4" Rough Country X-Flex Short Arm Kit (KOR Installed)
    Hydro 9000 Shocks
    Kevins Off-Road Adjustable Front Track Bar
    Custom Built Heavy Duty Front Driveline
    Limited Slip Dana 30 Front/Limited Slip Dana 44 Rear
    Ballistic Fabrication 1.5" Wheel Spacers
    31" BFGs
    250000+ Miles And Sill Running Strong
    dustin g's Avatar
    Nov 2010
    Gilbert AZ
    314
    They are a little stiff but loosen up after a few months.
    Hydro 9000 Shocks
    31" BFGs
    XJsport95's Avatar
    Feb 2011
    Michigan
    18
    I have the 4in X-series flex arms and it’s great. Yeah it’s a little stiff but when you put bigger equipment in your vehicle it will be until it has broken in. Really what you do to the jeep should reflect what you will be using it for. If this is mainly a daily driver i might look into some coil spacers for the small 2in lift you’re trying to achieve. Personally i would go with the 4in Kit because it’s not overkill. My ZJ is my daily driver not some off the wall 10in lift 35in tires jeep only built for the trails. In today’s economy it’s not sensible to run jeeps like that on the road. I know someone out there is going to read that and be all like yeah it is but the truth is it’s not. The 4in lift to me is a happy medium between daily driver and weekend trail rig and has served me well when I’ve put my ZJ through the trails.
  7. #7
    XJsport95's Avatar
    Feb 2011
    Michigan
    18
    Also before doing anything to the jeep I would go to advanced auto or AutoZone and get like 2 or 3 can of PB BLASTER or any type of penetrating oil and spray the S#!T out of all the nuts and bolts you’ll be putting a wrench on. I didn’t even have to pull out my torches when I did my lift because everything came apart so easy.
  8. #8
    tow_hook's Avatar
    tow_hook is offline Senior Member
    May 2009
    western pa
    183
    Post Re: 04 grand cherokee special edition needs lift
    Quote Originally Posted by cali_92 View Post
    A list would b nice if u have a couple of ideas.
    Anything from cheap and simple
    not sure on prices, but the options are: Old man emu, bds, ruff country, iron rock offroad, tera flex. With my 02' limited i did a tear 2" spacer and fit 265/70/17's with some rubbing, which ment trimming :) we did used ome coils, with bds control arms, and a tera 3rd link spacer, with rancho 9000 shocks.
    Current rides:
    57"cj3b, getting restoflyed :)
    95"yj, now on 33's
    93"xj, 37" r.i.p.
    02"wj, 33" km2's, and h.o.
    98" xj a wanta be rock krawler
    " bent, broke & twisted ( 4x4 club ) " are you?
    http://www.bbnt4x4.org/
  1. 2004 Jeep Grand Cherokee Cherokee,10" lift, GPS, TV's,System $13,300
    By gjs14 in forum Items for Sale, Trade, or Give Away
    Last Post: 03-07-2010, 05:41 PM
  2. Wanted: 89-91 Jeep Cherokee Laredo or Special Edition Cherokee [near WV]
    By rebelxgirl069 in forum Items for Sale, Trade, or Give Away
    Last Post: 07-12-2009, 03:21 PM
  3. Grand Cherokee Lift Kits
    By amuddyzj in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-01-2007, 11:57 AM
  4. 96 grand cherokee limited edition 4x4 and 87 wrangler yj
    By B.Jones in forum Items for Sale, Trade, or Give Away
    Last Post: 04-16-2004, 11:37 PM
  5. 98' Grand Cherokee Special Edition
    By Abugarcia in forum Items for Sale, Trade, or Give Away
