Starting Problem 97 JGC HELP!!!
BrnDave
Working on a 97 Grand cherokee limited.
Replaced ignition, tested starter, good Batt yet wont start does nothing when you turn the key seems like a anti theft device or N safety switch but i have no idea any help would be great.
Turns over or doesn't crank at all?. If the security system is causing this, there should be a tell tale lamp on the dash that would indicate the security system has activated the theft mode. If not, shift the trans. in neutral with the e-brake on and try to start it and see what happens.
Well found out that the number one ignition wire was cut just behind the grommet tied the wires together and presto engine cranks thanks for the help. just sad that i didnt notice it b4
