    Gary Safewright's Avatar
    Gary Safewright is offline Junior Member
    Jul 2011
    1
    2001 Grand Cherokee AC Condensate Drain Cleaning
    I have been battling water on the passenger floor board for a few weeks and finally got it solved.
    First i followed internet advice and drilled a small hole on the inside to allow me to blow out the drain line. The internet said the drain went down into the frame but this is incorrect on this model. It protrudes about an inch beyond the engine side of the firewall. The hole drilling was a waste.
    Next I got a cooling system type hose that would fit over the part protruding into the engine compartment. This hose had a ninety degree bend which got the drain out of the airflow from the engine. This almost eliminated the problem.
    Finally the foam that sealed the drain where it went through the firewall, on vehicle interior, had broken down and was leaking. I dug it out and filled the gap with a plumbers sealant.
    I hope this helps anyone that is having a similar problem
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,877
    Re: 2001 Grand Cherokee AC Condensate Drain Cleaning
    Nice writeup Gary, Thanks.
  1. Replies: 1
    Last Post: 03-26-2012, 03:43 PM
  2. 2001 grand cherokee rim question?????
    By 01bluejeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-25-2010, 12:28 AM
  3. 2001 Grand Cherokee start up problems, etc
    By roooookie in forum General Chat
    Last Post: 06-10-2005, 05:08 PM
  4. WTB: 96-2001 Chreokee or Grand Cherokee 4.0 6cyl Throttle Bo
    By TribeFan in forum Items for Sale, Trade, or Give Away
