    Fatherkey's Avatar
    Fatherkey is offline Junior Member
    Jul 2013
    2
    2000 grand cherokee turn signal hi beam issue
    Hi all! Hopefully someone here will be able to give an assist here cause I am stumped. 2000 Grand Cherokee Laredo. Passenger side FRONT turn signals do not work, nor blink with the hazards, nor does the hi-beam light on same side. I started with the basics... checked fuses... new bulbs, even switched drivers side to pass side cause I knew they worked and still nothing. Replaced the flasher, no help, replaced the switch, no help. Even went as far as thinking about a bad ground, so I ran jumper wires from the ground on each pigtail directly to a good ground on the body, still nothing... Am not sure where else to look.... ANY and ALL suggestions would be appreciated!
    Fatherkey's Avatar
    Jul 2013
    2
    Problem solved. Picked up a wiring harness from bone yard.... fixed. Old harness had a few pinched wires from the assembly being pressed against it over the years. Wanted to share in case anyone else runs across this.
    danthedent's Avatar
    danthedent is offline Member
    Apr 2013
    34
    Nice glad to see you figured it out your self always rewarding to figure out a problem
  1. 2000 Grand Cherokee Limited Driver Side Turn Signal Problem
    By cundifc in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-27-2009, 07:09 PM
  2. 89 Cherokee Turn Signal
    By AUSCFAN in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-20-2008, 12:34 PM
  3. ques about 2000 Grand Cherokee
    By 88WRANGRED in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-09-2004, 06:03 PM
  4. Buddy needs new transfer case for 2000 Grand Cherokee
    By Nick_Mur in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-05-2003, 01:50 PM
  5. 2000 Grand Cherokee Limited Garage Door Control
    By gte567e in forum Cherokee, Commander, Wagoneer and Liberty
