    Kathee67's Avatar
    Kathee67 is offline Junior Member
    May 2014
    1
    1986 Cherokee jeep, to install a new cable battery cord
    This jeep's name is Karma and sure likes to drain my bank account. My son and I are learning how to do basic care for the jeep. What I would like to know how to put the loom on the battery cable? Where is the connector that is somewhere under the hood to replaced the old cable connector.
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: 1986 Cherokee jeep, to install a new cable battery cord
    you get your batt cable replaced. Im not sure what you mean by "loom". Are you replacing the ground cable(black) or the hot cable(red)? The ground cable should attach to the - side of the bat and to the engine block or the frame. The hot should attach to the + side of batt and could either go to the starter solenoid and then starter, or straight to the starter.
    Tison78_CJ5's Avatar
    Tison78_CJ5 is offline Senior Member
    Mar 2014
    Marshall, NC
    195
    If you are working around the red wire on the battery, please remember the wrench can't touch the metal around it. The battery will cause Damage if shorted to the body. Please be careful.
    greg92jeepxj's Avatar
    greg92jeepxj is offline Official Supporter
    Apr 2013
    Staten Island n.y.
    2,000
    Agreed , do not let a wrench or metallic object touch metal while touching battery positive.
    Also, same for the alternator battery terminal , it is a live connection which will accomplish the same , sparks and burns ! Not to mention , a blown regulator . Got me scratching my head to over what is referred to as a loom. I think I may of come across it in a j.c. Whitney catalog once But can't say I make reference to it . Can you enlighten us ? Sure got us curious .
    carnuck's Avatar
    carnuck is offline Senior Member
    Jan 2009
    Seattle
    917
    Loom is actually the black plastic split cover that is to protect the cable inside from getting it's coating cut to the metal..
    '87 Comanche 4x4 lifted 5 1/2" on 33" tires 4.0L/AW4/NP242 $3500
    Perfect combination but too small to haul my Grand Kids and wife in.
    Mar 2014
    Marshall, NC
    195
    I had a feeling that was it, but just guessing. Great to know, Thanks.
  1. How To Install Serpentine Belt Jeep Grand Cherokee 1997-98 4.0L
    By 1ATony in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-24-2011, 06:14 PM
  2. 1986 4X4 Jeep Cherokee-The Ultimate Lamborghini Doors-TRULY AN EYE OPENER !!!!
    By trix32 in forum Items for Sale, Trade, or Give Away
    Last Post: 12-17-2005, 11:01 PM
  3. I have a new jeep! (To me anyway)
    By cewtwo in forum General Chat
    Last Post: 09-18-2003, 08:27 AM
  4. 86' jeep cherokee not engaging into gear..(new clutch) HELP!
    By pinned in forum Cherokee, Commander, Wagoneer and Liberty
  5. 1990 Jeep Cherokee Fuel Pump Installation
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
