    iforster04's Avatar
    iforster04 is offline Junior Member
    Aug 2015
    2
    Need Help with 2001 XJ
    Alright so here's the deal, awhile ago i bought my first jeep and i like it a lot. The only problem i have with it is that when i go to start it, it just doesn't start as quick as i'd like it to (it normally will take me 2 tries to get it started or about 30 sec of me turning the key the first time). I have replaced all the spark plugs and even put a new battery in it and I have no idea what it could be. If it helps the engine has a little over 150,000 on it, but its the 4.0 and I've heard these engines are practically almost bullet proof. Any help is greatly appreciated!
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    Re: Need Help with 2001 XJ
    Try turning the key to run (not start) for 15sec before starting and see if it improves. Your fuel system likely isn't holding pressure when off.
    iforster04's Avatar
    Aug 2015
    2
    Quote Originally Posted by Bounty__Hunter View Post
    I tried that and it helped a little bit. So if my fuel system isn't holding pressure when off, is there a good chance I have to replace the fuel pump then? (I'm not too tech savy when it comes to cars)
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,019
    You could get away with this for a long time. The valve is a part of the fuel pump assembly. However the valve failure is no indication of the pump failing.
    You could try the on off two times for five seconds. In the first five to ten seconds the fuel pump primes and pressurized the system. Being the valve bleeds back the lines are empty. Ine cycle may not be enough to fully prime the line.
  1. Need help with my XJ couple of issues: Squeak Noise & Ga
    By lnixon-88XJ in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-03-2003, 07:29 PM
  2. Need help with engine replacement
    By Mascarab in forum CJ YJ TJ and JK
  3. i need help with my last post(starting problem)
    By delsr1 in forum CJ YJ TJ and JK
  4. Need help with the "nutter " bypass
    By TerryMason in forum CJ YJ TJ and JK
  5. Need Help with Engine swap
    By TEYTEY in forum CJ YJ TJ and JK
Tags for this Thread
