    Delinda Singleton's Avatar
    Delinda Singleton is offline Junior Member
    Jun 2016
    1
    2001 Grand jeep Cherokee overheating
    Perhaps someone can help us, 2001 grand jeep Cherokee lardo keeps overheating &leaking antifreeze while idling, then continues to go higher in stop & go traffic. Thermostat & housing has been changed. What should we check next for the problem? Delinda Singleton
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,972
    Re: 2001 Grand jeep Cherokee overheating
    Any idea where the antifreeze is leaking from? I'd start with that - be sure to check around the water pump.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    greg92jeepxj's Avatar
    greg92jeepxj is offline Official Supporter
    Apr 2013
    Staten Island n.y.
    2,000
    X2 on the water pump . Sounds like the engine coolant is lost under pressure which may be the water pump. Whether you have the 4.0 liter six cylinder or the 4.7 liter V8 , the leak inspection will be similar . See if the front of the engine is wet or if you see coolant dripping from the water pump . Don't exclude things like hoses , radiator , overflow reserve tank or even the heater core. Are the Windows fogging even a little and is there a scent of coolant inside the cabin ? It will be a somewhat sweet smell but noticeable. You can try to loan a pressure tester from autozone if you live near one . With the engine off and cold ( no pressure ) you just remove the radiator cap and put on the tester and pump some pressure into the radiator/cooling system . Wherever the leak(s) is/are , the pressure will force out the coolant and your leak is found. Also , have you noticed any coolant dripping from the firewall area from the moisture drain for condensation from the air conditioning beside the water that normally drips from there ? If coolant is found to be dripping from there , the heater core is leaking . Be sure it's not a heater core hose connection that is leaking. Be sure the connections are not leaking and are tight . Use care when handling hoses on heater core connections under the hood since on some vehicles the heater core has plastic tubes and plastic tanks that the hoses attach to. Rough handling can cause cracks and on down the line , leaks. A heater core swap in a WJ is an expensive job since it entails much disassembly . You'll want to inspect to,the best of your ability before a mechanic gets their hands on it and spends all your vacation money for you. Wishing you the best . There are you tube videos on the heater core swap if your interested.
    JPNinPA's Avatar
    JPNinPA is online now Senior Member
    Feb 2009
    Dayton Ohio Area
    5,036
    All above. Verify you get all the air out when refilling. Ht he expansion tank is attached and filled to the line cold. Then be sure your radiator cap is only allowing fluid out to the hot line and not more than that. If so replace the radiator cap with a new 18 lb cap.
  1. 2005 Jeep Cherokee overheating when stopped or idle
    By Colby Nicholas in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-12-2013, 10:22 PM
  2. 1994 jeep cherokee overheating while ideling
    By rjmidbon in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-19-2012, 09:38 AM
  3. Jeep Grand Cherokee overheating...
    By Lyoungsjeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-02-2009, 08:26 AM
  4. 1988 jeep cherokee overheating
    By Cindi in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-29-2008, 12:19 AM
  5. 88 Jeep Cherokee Overheating
    By NW Jeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-19-2008, 11:59 AM
Tags for this Thread
