    Ryan Emig's Avatar
    Ryan Emig is offline Junior Member
    Oct 2016
    4
    2001 Grand Cherokee 4.0
    I have a 2001 WJ Grand Cherokee 4.0. I bought it yesterday with it missing bad, I ran the codes today and it was a random misfire code, misfire #1,2,3,4,5 and a bank one rich code. Any idea what this could be? It stumbles and misses at idle and even worse under load.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,026
    Being you just bought it and don't have the history. Check the fuel pressure. Check the spark plugs. Post up the make and part number of the plugs. Check the gap. Do a compression test. Verify you have spark. Check the plug boots to see they are not cracked or damaged.
    Also check for vacuum or intake leaks.
    Ryan Emig's Avatar
    Oct 2016
    4
    Re: 2001 Grand Cherokee 4.0
    I have new plugs, coil pack, and a fuel pressure guage on there way. I'm doing a compression and a combustion leak test tomorrow. Just wanted to see if someone knew something I didn't but as much as I searched, couldn't find much. Thanks for the reply JP
    98Chero's Avatar
    98Chero is offline Senior Member
    Jul 2006
    SW Arkansas
    226
    Also check for leaks in your cooling system. could be a blown head gasket. Hopefuly not but if the cooling water runs low your head gasket will take a beating for sure.
    I hope this helps
    1996 Cherokee Sport 4x4
    2002 Grand Cherokee Laredo 4x4
    2006 Liberty 4x2
    What can I say... I love Jeeps
    Ryan Emig's Avatar
    Oct 2016
    4
    I just did the combustion leak test, the blue liquid in clear tube, stuck in the radiator cap opening. It turned light green after about 4-5 minutes. So I'm guessing it's the head, since they're known to be crap. Then to top it off, when I was going to shut it off the oil pressure visage was at 0. I'm thinking I might as well get a used engine from Craigslist. This is just a vehicle I'm fixing to sell, trying to do it as fast and cheap as possible. Any input is appreciated.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,026
    No oil pressure could just be the sending unit.
  7. #7
    98Chero's Avatar
    Jul 2006
    SW Arkansas
    226
    Ya I had a sending unit that just needed to be cleaned. if you dont know how they work its a cheap replacement for a new one. If it is the head gasket it could cost 1.700.00 to replace it. Thats with a new water pump and cooling fan and igintion coil with a RnR on your radiator. I just payed that much on my 2000 Grand ! sould have run it across the scales because it has a leak in the heater core !
    2006 Liberty 4x2
  8. #8
    Ryan Emig's Avatar
    Oct 2016
    4
    I just bought a reman head for $300. The oil pressure visage started working again after I let it sit and started it again. I'm going to start with the head and go from there. I'll part this out before I put over $1000 into it. No way I'd pay $2000
  1. Newbie recently bought 2001 Grand Cherokee
    By kkcomp in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-16-2012, 09:39 AM
  2. 2001 Grand Cherokee Laredo Auto Trans Issue
    By David Black in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-08-2012, 01:23 PM
  3. 2001 Grand Cherokee AC Condensate Drain Cleaning
    By Gary Safewright in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-07-2011, 06:09 AM
  4. 2001 grand cherokee rim question?????
    By 01bluejeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-25-2010, 12:28 AM
  5. 2001 Grand Cherokee start up problems, etc
    By roooookie in forum General Chat
    Last Post: 06-10-2005, 05:08 PM
