    fenns's Avatar
    fenns is offline Junior Member
    Apr 2017
    London; UK
    1
    Greetings from new member in the UK with temp sensor question
    Hi all - forgive the brevity of my first post but I really need to get home and see my family.
    I am a recent XJ convert having inadvertently saved a 1996 Limited 4.0 from rotting on the street - a long story; perhaps for another time Being a UK vehicle it is right hand drive - like your US mail model.
    My question concerns the coolant temp sender located at rear of the engine block - the one that feeds the temp gauge (not idiot lights) . If I am able I will post photos to assist identifying.
    The male (?) connector has stated to breakdown (1st & 3rd pic shows the sensor removed from it's grey housing) due to age/heat but I have managed to jury rig a repair that sees to work .... for now anyway (see 4th pic). At some point I will need to replace both the temp sender & most importantly, this connector, but have failed to find a supplier.
    Can any one assist as I'd like to buy both temp sender, connector plus the coolant temp sensor (the one in thermostat housing) together?
    Ideally I go for Mopar, Crown or Standard parts.
    Thank I advance for any advice/assistance offered.
    Simon
    Attached Thumbnails Attached Thumbnails Greetings from new member in the UK with temp sensor question-img_4781.jpg
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,519
    Re: Greetings from new member in the UK with temp sensor question
    Welcome to Jeepz.com. I can't say if they will ship to the UK or not, but I like RockAuto.com for my standard replacement parts
    1996 JEEP CHEROKEE 4.0L L6 Temperature Sender / Sensor | RockAuto
    1996 JEEP CHEROKEE 4.0L L6 Temperature Sender / Sensor Connector | RockAuto
    I just did a quick search, so double check those are the correct parts before you buy.
    superj's Avatar
    Feb 2010
    texas
    5,754
    I cannot help on the connectors but wow, those really are breaking down. you might have to try just searching for automotive wiring plug, or something like that in google
  1. temp sensor
    By desertrunner in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-11-2013, 03:21 PM
  2. Ambient Air Temp Sensor
    By Crusty in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-26-2012, 07:10 AM
  3. 05 TJ Intake Air Temp Sensor
    By Medicjeff66 in forum CJ YJ TJ and JK
    Last Post: 09-03-2011, 09:08 AM
  4. Air temp sensor
    By Chester in forum CJ YJ TJ and JK
    Last Post: 10-03-2009, 12:12 AM
  5. Temp sensor
    By kis86 in forum CJ YJ TJ and JK
    Last Post: 02-23-2009, 12:31 PM
