    77joshuatd77's Avatar
    77joshuatd77 is offline Junior Member
    May 2017
    4
    95 grand cherokee
    Just bought jeep. Has no dash lights gauges. No fuel to fuel rail. Will turn over and run as long as feeding gas through intake. Is this a security thing? The jeep has been sitting for a year or more. Any answers or clues would be greatly appreciated.
    Sent from my LGL82VL using Tapatalk
    superj's Avatar
    Feb 2010
    texas
    5,685
    Re: 95 grand cherokee
    check the sensor on the transmission. the crank position sensor. it will possibly help with running but not lights
    almost done with all the yj stuff.
    k-2's Avatar
    k-2
    k-2 is offline Member
    Apr 2017
    57
    Auto basics -
    How are you with a test light and wiring diagram? Can post dia if you can use.
    Is there a remote starter - very problematic let us know.
    CK (Check) ign sw.
    CK ASD.
    CK Fuel ump fuse and relay
    May 2017
    4
    Does the crank sensor send a signal to fire the fuel pump? I have checked the relay and even with key to on i get nothing. There should at least be a 5 sec prime. Am not getting anything tho
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,501
    Yes
    JPNinPA
    Using Jeepz.com app
    k-2's Avatar
    k-2
    Apr 2017
    57
    more like 2seconds if engine not running.
    do you need diagram
  7. #7
    May 2017
    4
    Please
  8. #8
    k-2's Avatar
    k-2
    Apr 2017
    57
    start in PDC fuses relays.
  9. #9
    May 2017
    4
    Thanx gentlemen. Success. New crank and battery and we are up and running! Bought this 95 grand for $160. New governor solenoid tighten up the bands on trans trans filter and gasket set. And it's up and running!!
  10. #10
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,501
    Congrats
    JPNinPA
    Using Jeepz.com app
  1. Replies: 3
    Last Post: 07-22-2015, 02:08 PM
  2. 2004 Jeep Grand Cherokee Cherokee,10" lift, GPS, TV's,System $13,300
    By gjs14 in forum Items for Sale, Trade, or Give Away
    Last Post: 03-07-2010, 05:41 PM
  3. NEW 1986 grand cherokee/grand wagoneer Hitch
    By jeepguyracing in forum Items for Sale, Trade, or Give Away
    Last Post: 02-17-2010, 07:29 PM
  4. Grand Cherokee Pitman and Cherokee Driveshaft
    By blazntn in forum Items for Sale, Trade, or Give Away
    Last Post: 06-23-2004, 04:52 PM
