    90renixxj's Avatar
    90renixxj is offline Junior Member
    May 2017
    3
    Steel tube near output shaft
    I working on the np231 in my 90 Cherokee and I was taking off what I can only really refer to as the bearing or output shaft cover? When I trying to pull it off it had a steel tube attached to the inside of it... I'm guessing a lube tube? So I popped the tube off and today I got my new driveshaft and went to put it all back together and can't seem to find the steel tube to reattach. Any tips?
    Sent from my iPhone using Tapatalk
    superj's Avatar
    Feb 2010
    texas
    5,734
    Re: Steel tube near output shaft
    no idea here. I don't know what you are talking about
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    259
    Is this a good/helpful diagram?
    Yes you need it - are you asking for a source to get replacement OR instructions ?
    Attached Images Attached Images
    superj's Avatar
    Feb 2010
    texas
    5,734
    that helped me a lot, ha ha ha. now I know what we are talking about
    90renixxj's Avatar
    May 2017
    3
    Lol that diagram is perfect I was just trying to see what the hose lead to
    90renixxj's Avatar
    May 2017
    3
    Thank uou
  1. Sleeve the output shaft?
    By GirlzJeep in forum CJ YJ TJ and JK
    Last Post: 09-22-2016, 12:07 PM
  2. 98 wrangler output shaft
    By loosecannon in forum CJ YJ TJ and JK
    Last Post: 09-01-2014, 09:12 AM
  3. T-case output shaft seal
    By JohnnyO in forum CJ YJ TJ and JK
    Last Post: 04-07-2010, 09:17 AM
  4. A bent output shaft???? Really!
    By Dagan Johnson in forum General Chat
    Last Post: 05-19-2009, 03:55 AM
  5. SYE output shaft to stock output shaft...?
    By Joopin in forum CJ YJ TJ and JK
    Last Post: 12-14-2003, 03:15 AM
