    jd340's Avatar
    jd340 is offline Junior Member
    Jul 2017
    New Zealand
    3
    Water leak at door seal
    Hi all. My wifes 97 XJ has a leak under the left hand front door seal, as per attached photos. Just wondering if anyone has had this leak and what you have done to stop it. And if you're wondering what the white powder is, it's flour my wife put down so we could track and leaks. Any help would be much appreciated.
    Water leak at door seal-img_20170717_083321.jpgWater leak at door seal-img_20170717_074403-1-.jpg
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    299
    Re: Water leak at door seal
    being on the inside of the 'lip' maybe check door drains - look bottom of door
    xt master's Avatar
    xt master is offline Senior Member
    Nov 2008
    NE-PA
    1,656
    I am having a similar issue on my TJ. My problem is the window seal is bad then it gets inside the door then leaks inside the Jeep.
    Sent from my Pixel XL using Jeepz.com mobile app
    jd340's Avatar
    Jul 2017
    New Zealand
    3
    Hi. We have checked door drains, all good. Thanks for your reply.
    jd340's Avatar
    Jul 2017
    New Zealand
    3
    Yeah, that was the next thing to check out, thanks
    XjayPL's Avatar
    XjayPL is offline Junior Member
    Aug 2017
    Burbank, California
    5
    The rubber door seals on the upper jam of the door have been an issue on some cherokees. They dont make a tight seal between door and frame, a quick and cheap fix is to get clear hose tubing (i forget the diameter) and run it along the inside of the door seal. It creates a stiffer seal against the frame. My .02
  7. #7
    vinn's Avatar
    vinn is offline Member
    Dec 2015
    86
    my 94 yj with hard top; leaked severly on the pasenger side when i bought it a few years ago. my first modern jeep. after many hours of "door seal dittling" found the problem in the air box "water drain device". found it by temporarily covering the air inlet. no solution found. vinn
  1. 258 i6 jeep cj7 main seal leak!
    By ShakenBake in forum CJ YJ TJ and JK
    Last Post: 08-02-2016, 11:57 AM
  2. Cowl Seal leak
    By Blanco Wrangler in forum CJ YJ TJ and JK
    Last Post: 02-02-2013, 08:59 PM
  3. water leak
    By BlueRidgeRunner in forum CJ YJ TJ and JK
    Last Post: 03-04-2011, 04:00 PM
  4. oil leak not from rear main seal
    By evaddave in forum CJ YJ TJ and JK
    Last Post: 03-12-2009, 07:59 PM
  5. rear pinion seal leak
    By bryanjeep in forum CJ YJ TJ and JK
    Last Post: 11-22-2003, 11:57 AM
