    MnSkol's Avatar
    MnSkol is offline Junior Member
    Aug 2017
    3
    Door Locks Not Working
    Hello all.
    I have a 2004 Jeep Liberty. Recently my power locks stopped working. I have to manually lock and unlock doors. My key fob does not do anything. Even when I try to unlock doors using lock/unlock button I get nothing. I cannot open rear hatch as it is locked and there is no spot to unlock it with a key.
    I replaced the fuse and every time I test it blows. I am hoping somebody might know what the problem is. A friend told me that the drivers door lock acts as a master for all the locks. He said it latch may need to be replaced???
    Has anybody experienced this?
    Any thoughts will help. Thank You.
    xt master's Avatar
    xt master is offline Senior Member
    Nov 2008
    NE-PA
    1,648
    Re: Door Locks Not Working
    If the fuse is blown there is a reason.
    1. A lock may be bad and drawing too much current.
    2. A switch may be bad and either drawing too much power or shorting out.
    3. You have damaged wiring that is shorting to ground.
    I would start at the driver side lock button. If you have a meter and know how to troubleshoot wires I would start by trying to meter from the switch to locks for a ground. I would also disconnect the switch replace the fuse and see if you can get power to the switch. If yes attach switch only and see if you get power out of the switch. If yes disconnect all the locks and start connecting one at a time until the fuse blows that will tell you at least what door is causing the issue.
    If I had to guess I would say the connection from the cab to the door would be the issue due to the fact that part moves and could have punched something causing a short.
    Good luck electrical problems are always a pain.
    Sent from my Pixel XL using Jeepz.com mobile app
    MnSkol's Avatar
    Aug 2017
    3
    Thanks. I will try that.
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    213
    let us know if still working this-
    FYI lift glass working ok - then there is a manual release for tail gate in rear - small access panel on trim panel - check owners manual for info.
    My guess is the swing gate is where the issue Is .
    MnSkol's Avatar
    Aug 2017
    3
    After a lot of testing I found the problem. It was the front passenger lock switch. I disconnected it and everything works fine. Connected it and fuse blew every time I tested it. Thanks for the input and replies.
    xt master's Avatar
    Nov 2008
    NE-PA
    1,648
    Glad to hear you found the problem.
  1. door locks
    By tales55 in forum CJ YJ TJ and JK
    Last Post: 02-06-2010, 03:44 PM
  2. Door and Hood locks?
    By jchooper12 in forum General Chat
    Last Post: 07-19-2006, 07:14 PM
  3. Door locks
    By 90Xjay in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-22-2004, 09:46 AM
  4. Electric Door Locks
  5. defective door locks
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
