    CruleNIGHTWING's Avatar
    CruleNIGHTWING is offline Junior Member
    Mar 2017
    19
    Full time 4 wheel drive
    I was driving my 02 jeep grand cherokee threw some heavy weather about a week ago and tried to use my full time 4 wheel drive setting. I moved the shifter into the correct setting and made sure the Patr time light went off. When I hit the gas, i was still i 4 wheel Part time. No mater if I am moving or sitting still I cant get it in 4 wheel Full time. Please help. Thanks
    Sent from my SM-S820L using Jeepz.com mobile app
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,323
    Re: Full time 4 wheel drive
    Likely a simple adjustment of the shift linkage. Look at the linkage on the transfer case and you'll see a rod passing through the shift arm with a bolt holding the rod in place.
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    261
    I am guessing a select trac NV242?
    If so did you try to use 2wd? Sometimes T'cases get 'stuck'* in 4wd - shifting to N or reverse may unload Tcase from the current position .
    *Torque locked would be a good description
    Attached Thumbnails Attached Thumbnails Full time 4 wheel drive-st_shifter-nv242.jpg
    Mar 2017
    19
    I can get it back in 2wd bu ba king up about 30 feet or so. Its getting into 4 full time that seems to be giving me the trouble. I will be checking the linkage as soon as i can. Thanks
    k-2's Avatar
    k-2
    Apr 2017
    261
    what about N and 4lo - can you select those?
    trying to help if this Is slect trac NV242 confirm..... use wd40 when checkg cable and linkage movement
    Attached Thumbnails Attached Thumbnails Full time 4 wheel drive-nv242-fyi.jpg
    Mar 2017
    19
    Yea it goes in N and 4lo. I believe it is select trac. Ill double check when it get home. Wife took it to work. Ill check the linkage and tires.
  7. #7
    Mar 2017
    19
    I do know the light for the 4 wd part time does go off.
  8. #8
    98Chero's Avatar
    98Chero is offline Senior Member
    Jul 2006
    SW Arkansas
    224
    I never understood the "Part Time 4x4 " on my 02 Grand. When i am at home i work part time on things. How does it know to be 4x4 and sometimes 2x4 ?
    1996 Cherokee Sport 4x4
    2002 Grand Cherokee Laredo 4x4
    2006 Liberty 4x2
    What can I say... I love Jeeps
  9. #9
    k-2's Avatar
    k-2
    Apr 2017
    261
    part time and 4lo are serious 4wd. Wheels need to slip during turns, so no pavement.
    4wd full time is akin to AWD, the front and rear drive shafts make use of a differential and are not locked.
  10. #10
    Mar 2017
    19
    It is select track
  11. #11
    Mar 2017
    19
    I know what each 4 wd setting is for. I live in indiana and play in mud. Lol. Not to often. About once a month. Just to keep everything lubed.
  12. #12
    Mar 2017
    19
    Ok. Sorry it took so long to get back to everyone. I checked everything y'all suggested and nothing worked, so I took it to a Jeep dealer. Turns out that my jeep like to be moving at about 20 mph to move in to 4 we full time. It won't go into it if I'm at a stand still. I can put in in any other position at a stand still but Full Time needs at least 20 mph. So that works now. Thanks for all the suggestions and help. It's nice to have a place to go to for help.
  13. #13
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,675
    Cool thanks for posting the fix.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Noise from front differential, goes away when in part time four wheel drive??
    By DRAGONSYCLES in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-18-2013, 11:15 PM
  2. front wheel drive line turns all the time
    By 98Chero in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-10-2011, 08:32 PM
  3. Front drive shaft turning in 2 wheel drive
    By russ777 in forum CJ YJ TJ and JK
    Last Post: 06-07-2009, 11:18 AM
  4. comman trac part time 4 wheel drive
    By NEALSTER in forum CJ YJ TJ and JK
  5. part time vs full time
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
