    oldmanXJ's Avatar
    oldmanXJ is offline Junior Member
    Sep 2017
    2
    1990 XJ missing problems
    Ive got a 1990 Xj that is doing funny shit.
    ive recently replaced the plugs, wires, distributor rotor and cap, IAC valve. every one of the parts ive replaced have made the jeep run better for about a week. then back to sputtering. the sputtering is inconsistent. cold motor, hot motor, sometimes not at all. sometimes only when I hit bumps????? was thinking electrical issues but maybe gas related.
    Please Help love my Jeep
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    261
    Re: 1990 XJ missing problems
    Guessing A 6cylinder?
    Do basics -
    fuel pressure use gauge. Then KOEO watch pressure drop ie drops Xpsi in 5min/
    Check for vacuum leaks.
    Spark at all plugs
    Plugs wet, dry, black,tan?
    k-2's Avatar
    k-2
    Apr 2017
    261
    try this for a code ck
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,675
    Does the PCM throw a CEL or does it blink?
    Clean the battery terminal and connectors.
    Clean the opposite end of the grounds.
    Check for vacuum leak by spraying around the intake and vac lines.
    Check fuel pressure off, idle and at rpm
    What did your old plugs look like?
    Regards,
    JPNinPA
    Sent using TapTalk
    oldmanXJ's Avatar
    Sep 2017
    2
    looks like ill have to get those lights to work first
    superj's Avatar
    Feb 2010
    texas
    5,734
    I bet its a wiring issue. like a bump or a shift in the wires makes it run bad.
  1. Missing IAC
    By gbclowes in forum CJ YJ TJ and JK
    Last Post: 04-18-2014, 09:31 PM
  2. Missing In Action
    By stumblnyj in forum General Chat
    Last Post: 11-13-2012, 05:56 PM
  3. Am I missing something here? or am I just getting too old?
    By Turbogus in forum CJ YJ TJ and JK
    Last Post: 08-23-2012, 04:06 PM
  4. 1990 cherokee abs problems
    By imderrick247 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-16-2009, 08:27 PM
  5. Am I missing something??
    By Jason4x4 in forum CJ YJ TJ and JK
    Last Post: 01-10-2008, 06:53 PM
