    XJReaper's Avatar
    XJReaper is offline Member
    Jan 2018
    56
    Tomorrow starting the engine swap on the 94 cherokee
    So the blocks broken from some muddin and wheelin. Tried to drill deeper and tap the new hole using a slightly larger bolt and it didn't really work out the way I had foreseen.
    Being I have a donor jeep in the garage I'm going to pull the engine and swap it over. I've been kind of sitting back and being lazy about the whole situation till this past Friday when my son was rear ended in my daily driver. Now all vehicles are down so I guess I have to get back to wrenching on the beasts.
    I will take pics of the progress for everybody. Just wish I had the money to make the pics worth it. But it's a basic budget swap for now.
    Have a great one all and I will post soon.
    Sent from my [device_name] using Jeepz.com mobile app
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,383
    Re: Tomorrow starting the engine swap on the 94 cherokee
    Best of luck.
    XJReaper's Avatar
    Jan 2018
    56
    Quote Originally Posted by Bounty__Hunter View Post
    Best of luck.
    Thank you. Got everything undone in the donor but the exhaust down tube, tranny, and passenger motor mount.
    Tomorrow I'm starting on the receiving patient.
  1. Cherokee to TJ engine swap
    By ken.wescoat in forum CJ YJ TJ and JK
    Last Post: 03-15-2015, 08:43 PM
  2. Engine Swap issue with '04 Grand Cherokee engine into '00 JGC Laredo
    By DivineImpressions in forum CJ YJ TJ and JK
    Last Post: 08-03-2014, 07:12 AM
  3. Cherokee Engine Swap: 2JZ-GTE
    By child9 in forum Jeep Performance
    Last Post: 01-09-2013, 01:42 PM
  4. Need help with engine swap with 96 cherokee
    By solomotorsports in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-15-2009, 09:33 PM
  5. 89 YJ Engine Swap to a 89 4.0L from a Cherokee
    By Josepkelk in forum CJ YJ TJ and JK
    Last Post: 04-08-2006, 11:22 PM
