    JustLivin's Avatar
    JustLivin is offline Junior Member
    Nov 2018
    1
    2012 Liberty. HVAC Vacuum line leak. Location?
    I'm super new to all of this so my terminology may be off. I also greatly appreciate any help all your pros can give me. I've narrowed my problem down to 100% having a vacuum leak in the floor HVAC. I've come to this conclusion because my floor vents default to defrost and I get a whining noise behind the glove box area when I let off the gas when driving. My question is, how do I find this vacuum line I'm looking for? (the floor vent vacuum).
    Thank you!
    Jerry
    JPNinPA's Avatar
    JPNinPA is online now Senior Member
    Feb 2009
    Dayton Ohio Area
    4,275
    Re: 2012 Liberty. HVAC Vacuum line leak. Location?
    Likely on the passenger side firewall in the engine compartment you will find the vac line. Trace it back to the engine looking for leaks. There may be a T splice that goes under the battery to a vac reservoir Then on the interior.
    One symptom is as you mention default to defrost the other is high idle. If the leak isn't obvious you can take carb cleaner or WD 40 even water in a spray bottle. Start your engines and let it idle. Spray the vac line starting at the engine to the firewall. Listen for the idle to change. When it does you found your leak.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. hvac vacuum leak 97 XJ
    By twinkiedooter in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-20-2015, 08:29 PM
  2. 2002 jeep liberty o2 sensor location
    By fedexsdd in forum Washington Jeep Forum
    Last Post: 02-03-2015, 11:47 AM
  3. 4wd vacuum line?
    By superspud87 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-21-2009, 12:48 AM
  4. Vacuum line Q re '79 CJ5 304/2100
    By RandyS in forum CJ YJ TJ and JK
    Last Post: 03-26-2008, 11:59 AM
  5. 77 cj vacuum line
    By wolverine in forum CJ YJ TJ and JK
