    michaelc291's Avatar
    michaelc291 is offline Member
    Oct 2016
    Alicante, Spain
    50
    Speedo has gone erratic
    On my 1994 XJ RHD my speedo has sometimes started jumping up to 80kmh irrespective of what speed I am doing. (It came with KM/H rather than MPH). Sometimes it is fine.
    If I continue to drive with it stuck at 80 it may suddenly start to give the right reading. The needle is steady and does not flap about like the old cable driven ones did sometimes.
    To be honest I am not sure if it is mechanical or electronic, though my bet is electronic.
    Has anyone had this problem and what can be done to sort it?
    If I have to find a second hand head, how can I clock it to match the car's original mileage? The mileometer (odometer) is mechanical.
    I'm looking forwards to your suggestions. Thanks all. Mike.
    Attached Thumbnails Attached Thumbnails Speedo has gone erratic-cimg2906.jpg
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,582
    Re: Speedo has gone erratic
    Have you ever replaced the speedo gear? If the gear is not seated or clocked right in the housing you could end up with chipped or mushed teeth.
    Regards,
    JPNinPA
    Sent using TapTalk
    mark sr's Avatar
    mark sr is offline Senior Member
    Apr 2010
    east tenn
    247
    I don't know for sure but I'd be inclined to think your speedo is cable driven. You have to disassemble the speedo to reset the odometer. I've done it before but it's been a long time ..... and technically it's illegal.
    Oct 2016
    Alicante, Spain
    50
    Thank you for the suggestions. I looked at gears on the net and there seem to be dozens to choose from. Why are there so many?
    I think I'll get underneath and see if it has a cable or a sender attached. I agree about clocking the clock but is just from my convenience and to keep it right on the test cert. (just don't tell anyone).
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,582
    So many? : to cover/correct all gear tire size combinations that result in different speed and odometer readings.
    Oh and being you told only me on an open forum. Iíll keep it just between us.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,582
    Just another thought. Dash board connector behind the dash. It Often loosens causing various errors.
  7. #7
    Oct 2016
    Alicante, Spain
    50
    Thanks again for the suggestions. As the weekend is coming I'll get the screwdrivers out. If I need a replacement head has anyone got one they would part with (for a small fee)?
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,582
    Verify what engine you have. You might also post in the swap meet area with an appropriate title. Click bait
    Regards,
    JPNinPA
    Sent using TapTalk
  9. #9
    Oct 2016
    Alicante, Spain
    50
    Things have taken a turn for the worse. After my last post things went back to normal so all was good. The other day I pressed the trip reset button and it stuck partly reset. I pressed it a few more times but did not manage to get it to reset. What has happened now is the the main mileometer (odometer in American) has also stopped working.
    My thoughts are that there is some sort of mechanical failure in the cogs that rotate the thing. The actual speedo part still works but sometimes still sticks at 80.
    I think I will definitely need a new speedo head now.
    Are there any suggestions that could be useful?
  10. #10
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,860
    If the odometer is broken, then I'd start looking on ebay for one that has about the same mileage as yours
    They appear to be relatively cheap:
    https://www.ebay.com/sch/i.html?_fro...LH_TitleDesc=0
  1. Speedo
    By homeboundcat in forum CJ YJ TJ and JK
    Last Post: 01-25-2014, 03:34 PM
  2. Speedo
    Last Post: 11-20-2013, 12:41 AM
  3. Erratic temp
    By Atlas in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-14-2012, 11:26 PM
  4. Jeep Cherokee 1997 Erratic idle and jumpy accelaration
    By olrac in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-23-2009, 06:29 AM
  5. WTB 92-95 Speedo
    By fgcox1 in forum Items for Sale, Trade, or Give Away
    Last Post: 10-14-2008, 11:50 AM
