    Shadowsqdldr's Avatar
    Shadowsqdldr is offline Junior Member
    Jun 2019
    Long Island New York
    3
    97 Jeep Cherokee XJ won't start
    Good Day all,
    I have a 97 Jeep Cherokee XJ that recently had the engine rebuilt. The engine is in and everything is connected but she won't turn over, (strong crank but no start). I have fuel coming out the Schrader valve and she won't even start with starter fluid in the throttle body. I can hear the fuel pump at the fuel cap and smell fuel at the engine when trying to start. I put a spark plug tester on at the plugs and coil and it lights up. It has a brand new coil, spark plugs, fuel injectors, distributor rotor, and crank position sensor (OEM). Everything in the engine bay has either been reconditioned or replaced, starter, alternator etc; could it be off time? Also to note, I did the big seven cable upgrade. Any solutions or leads will be greatly appreciated.
    97 Jeep Cherokee XJ won't start-image.jpeg97 Jeep Cherokee XJ won't start-image.jpeg
    dusterdude's Avatar
    dusterdude is offline Junior Member
    Feb 2012
    13
    Re: 97 Jeep Cherokee XJ won't start
    If you're saying the spark plug is firing.I would do a compression check next.
    Sent from my LG-US601 using Tapatalk
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,076
    Nice looking engine bay.
    Engine has never been started and won't?
    Make sure all of your vac ports are used or closed.
    The intake is seated properly.
    Tb gasket
    IAC is plugged in and seal is on it.
    All the seals are on the injectors and they are firing.
    Connectors to the injectors are not crossed.
    The rail is plugged in and plug boots not cracked.
    Plugs are correct PN and gapped properly.
    Check the fuel rail pressure.
    OPDA is out of sync.
    Any codes?
    Regards,
    JPNinPA
    Sent using TapTalk
    Jun 2019
    3
    Quote Originally Posted by dusterdude View Post
    Thank you for your suggestion, I ordered a compression tester should be here in a couple of days.
    Jun 2019
    3
    Thank you for your suggestions, I will go down that list as best I can. The engine is completely rebuilt and was primed by the machine shop; She hasn't been started. I did put a scanner on it and she did not throw any codes.
    dusterdude's Avatar
    Feb 2012
    13
    Let us know how it goes
  7. #7
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,076
    Quote Originally Posted by Shadowsqdldr View Post
    You know some stores loan them. O’Reillys is one.
  1. 2004 Jeep Grand Cherokee won't start (or start to turnover)...
    By richdemarco in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-05-2019, 01:38 PM
  2. 2004 Jeep Grand Cherokee sometimes won't start.
    By Beep Beep Jeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-09-2016, 11:35 AM
  3. 97 jeep grand cherokee 4.0 4wd cranks will not start
    By JAKE001 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-14-2016, 11:14 PM
  4. 03 Jeep Grand Cherokee won't start at times
    By sodbuster2x in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-04-2009, 03:12 PM
  5. 90 Jeep Cherokee won't start-HELP!
    By jhups in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-21-2003, 04:56 PM
