    lost coyote's Avatar
    lost coyote is offline Junior Member
    Jul 2019
    2
    Rough country 4 lift kit rattling noise
    I have a 1998 Jeep Grand Cherokee Laredo 4.0.
    Just installed a rough country 4 lift kit, adjustable track bar, 1.5 wheel spacers and 31 BFGs. Had it aligned also.
    There is quite a loud loose sounding rattle from underneath. Its in the flex of the vehicle as it happens. I cant pin point it, driving me crazy. Does anyone have experience with this?
    I have a buddy with the 3.5 kit and his does this as well. Just not nearly as bad.
    Jeepergeo's Avatar
    Jeepergeo is offline Senior Member
    Dec 2010
    California
    405
    Re: Rough country 4 lift kit rattling noise
    Check the joints on the arms. Those joints can be a bit noisy compared to stock suspension, but not terribly noisy.
    Get the vehicle into a flexing position, block the wheels carefully, and then climb under, grasp each component one at a time, and give it a good tug to see if you can pinpoint the noise. Make sure to try several flex positions, both compressed and uncompressed.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,579
    Things that come to mind are brake lines. Axel vent tubes. Anything attached to the axel.
    Did the lift package include control arms and extended sway bar links? If not check your old sway bar connects snd bushings. Also control arm bushings and hardware.
    Check u joints as well. Axels and shafts.
    Jul 2019
    2
    It was the lower control arm connection to the axle. The new ones were slightly narrower than the OEM. Or my stock housing was blown out and wider.
    Either way, its taken care of now. Thanks.
  1. Rough country lift kit
    By CashJack158 in forum CJ YJ TJ and JK
    Last Post: 10-30-2010, 08:07 PM
  2. Rough Country Lift help
    By John_Stover in forum CJ YJ TJ and JK
    Last Post: 07-11-2010, 08:04 PM
  3. Rough Country Lift
    By Wranglerman21 in forum CJ YJ TJ and JK
    Last Post: 11-25-2009, 04:07 PM
  4. Rough country Lift II
    By jeepfan555 in forum CJ YJ TJ and JK
    Last Post: 09-05-2004, 04:24 PM
  5. Rough Country Lift
    Last Post: 08-26-2004, 09:39 PM
