    KSE's Avatar
    KSE
    KSE is offline Junior Member
    Aug 2019
    8
    2013 Jeep Grand Cherokee Dashboard "BRAKE" light
    Hi
    My Jeep Grand Cherokee dashboard sometimes displays "BRAKE" light . I check with the mechanic and he seems to guess with the diagnosis that its the Vaccum pressure sensor which is not working and needs to be replaced.
    He checked everything else and seems to be ok.
    Can somebody suggest a link online what I should be looking for and buy ? Also a vedio link so that I can replace by myself.
    Appreciate your help.
    Thanks
    K
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,017
    Re: 2013 Jeep Grand Cherokee Dashboard "BRAKE" light
    Quote Originally Posted by KSE View Post
    Hi
    Thanks
    K
    For parts check rockauto.com.
    What I can tell you to check is your brake fluid level can cause the brake dash light. Check the brake fluid level. Check the connector to the sensor on the side of the brake fluid resivor. This sensor is a float inside. These go bad sometimes and sometimes it can be bad brake fluid.
    Regards,
    JPNinPA
    Sent using TapTalk
    KSE's Avatar
    KSE
    Aug 2019
    8
    This part was recommended by the mechanic and he mentioned it was highlighted as a part of diagnosis. He mentioned brake fluid is ok.
  1. Jeep Grand Cherokee named "SUV of Texas"
    By TerryMason in forum General Chat
    Last Post: 12-15-2011, 08:24 AM
  2. "Brake" warning light?
    By Prrthd5_0 in forum CJ YJ TJ and JK
    Last Post: 09-02-2011, 09:51 AM
  3. "Check gage" light on 2004 Jeep Grand Cherokee
    By Duke2000 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-04-2009, 05:25 PM
  4. 1997 Jeep Cherokee Sport "Check Engine Light"
    By balloo93 in forum Cherokee, Commander, Wagoneer and Liberty
  5. Cherokee Brake Conversion from 10" to 11" rear bra
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
