    theesublimeone's Avatar
    theesublimeone is offline Junior Member
    Jul 2010
    8
    2011 Jeep Liberty - heat not working on driver's side
    Hey all,
    The heat in my 2011 Jeep Liberty is no longer hot, it just blows cold air. The passenger side blows warm air, but probably not as hot as it used to.
    One shop said it would cost $1-$2k to fix, as there is apparently an issue where 'stuff' gets clogged into the - something - and it's behind the engine block.
    Is that true? Is there any other way of clearing this out that is slightly more affordable?
    Thank you in advance for your help and advice!
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,951
    Re: 2011 Jeep Liberty - heat not working on driver's side
    Is it all the vents (i.e. floor, defrost, etc)?
    Any chance they said the "heater core" was clogged?
    My 2005 Wrangler Build Thread
    Oct 2019
    2
    Has the shop done a self diagnostics and tried a calibration on HVAC module?
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,953
    Have you had a antifreeze flush and fill? It is possible the heater core is clogged. You could flush these yourself easily.
    Ill check but is there a flow valve to your heater core?
    The fins inside can get clogged if you have a lot of debris in the vehicle floating around. It gets sucked up and filtered by the heater core.
  1. 88 jeep yj heat not working
    By 88jeepn in forum CJ YJ TJ and JK
    Last Post: 04-19-2012, 02:35 PM
  2. 2011 jeep liberty sport hand brake
    By yamajj in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-29-2011, 10:29 AM
  3. 2011 Jeep Liberty Hitch Wiring Harness
    By numnutter in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-07-2011, 03:57 PM
  4. 2011 jeep liberty
    By Metalrain300 in forum General Chat
    Last Post: 01-09-2011, 10:20 PM
  5. Passenger side to driver side Seat swap?
    By scooter7728 in forum CJ YJ TJ and JK
    Last Post: 11-16-2009, 12:28 AM
