    karfm's Avatar
    karfm is offline Junior Member
    Dec 2019
    NV
    1
    89 Laredo wont start
    New NSS new coil what do i check next? It is an 89 Cherokee Laredo 4.0 6, stock Chrysler 4 speed automatic 4 wheel drive
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,972
    Re: 89 Laredo wont start
    Not very familiar with the older Cherokee - any check engine lights?
    Do you have something like this that you can test for spark with?
    https://www.amazon.com/JND-Fool-Proo.../dp/B0042KJV9U
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    mark sr's Avatar
    mark sr is offline Senior Member
    Apr 2010
    east tenn
    273
    My 1990 cherokee didn't have a check engine light or means to plug up a code reader. IF I remember correctly there were limited codes you could get by turning the key and counting a flash in the dash. Sorry my memorably isn't better.
    Wash it running ok prior to the coil change?
    dusterdude's Avatar
    dusterdude is offline Junior Member
    Feb 2012
    13
    If it has a check engine light,you can google how to read chrysler obd1 codes
    Sent from my LG-US601 using Tapatalk
    masterbrewer's Avatar
    masterbrewer is offline Junior Member
    Dec 2019
    2
    Spark, fuel and compression you need all three. You have to find out which one your missing. Pull out a spark plug and hold it against the engine while a buddy tries to start the jeep. do you see a spark, Yes/No. If you have a spark have a buddy try to start the Jeep while you spray starting fluid into the air cleaner or carb. Did it try to start, if so you have a fuel delivery problem. Check as to why your not getting fuel. If it didn't try to start check and log the compression in each cylinder.
  1. Wont start
    By robsyz426 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-28-2015, 07:33 PM
  2. wont start
    By nathanbpd in forum CJ YJ TJ and JK
    Last Post: 12-05-2011, 11:39 PM
  3. 88 Cherokee Laredo/wont start
    By Jewel in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-27-2007, 08:14 PM
  4. wont start\wont drive
    By i-love-jeep in forum CJ YJ TJ and JK
    Last Post: 10-10-2006, 10:58 PM
  5. Wont Start
    By THEO in forum CJ YJ TJ and JK
    Last Post: 05-10-2004, 01:00 PM
