    Werdgra's Avatar
    Werdgra is offline Junior Member
    Dec 2019
    1
    Hesitation while driving at freeway speeds
    I have a 99 2 door XJ, 4.0L 6 cylinder 4x4. I recently replaced the distributor after getting a check engine light for the camshaft positioning sensor. I started it up and it ran fine after a test drive. The next time I started it up it ran very tough, sputtered and threw a code. I removed the distributor, repositioned it and after replacing the problem seemed to be fixed.
    However, shortly after replacing the distributor, I started getting a hesitation from my engine at freeway speeds. It seldom happens in a lower gear but it feels like the jeep is hiccuping. Its a very unsettling feeling and I want to address it and fix it as soon as possible. There are no codes that pop up when this happens and it usually happens between 50-70mph. Any ideas of what to check or where to start?
    I also recently got a code p1694 and p1698 not sure if these could be related but thought I would mention it. These codes have come and gone and im not sure if it is the TCM or a wiring issue.
    Any help would be greatly appreciated.
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,972
    Re: Hesitation while driving at freeway speeds
    That's a tough one. The hesitation never happened on the old distributor right?
    I'd expect some sort for check engine light if the wires were mixed up, however I'd start by checking those - make sure you have each plug wire going to the proper cylinder.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,031
    For the hesitation does it happen at a specific peddle position?
    P1698 - No CCD Messages received from PCM Bus communication failure to PCM. A Companion DTC was set in both the ECM and PCM. DTC P1698: NO BUS MESSAGES RECEIVED FROM PCM Monitor & Set Conditions PCM is monitored for receiving BUS messages with ignition on and engine off and with engine running. DTC may set if there is no communication with the PCM.
    There is a lengthy troubleshooting method. Ill post up later. For now please answer the first question.
    masterbrewer's Avatar
    masterbrewer is offline Junior Member
    Dec 2019
    2
    Possible timing issue. Was the distributor timed when it was installed. Too much advance would cause it to hesitate on the highway when you tried to accelerate.
  1. Sputtering at speeds over 40
    By jimi003 in forum CJ YJ TJ and JK
    Last Post: 01-03-2011, 09:51 AM
  2. Shaking at high speeds
    By 01jeepgc in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-10-2010, 12:46 PM
  3. 4 Hi engaged at Highway speeds... Opinions?
    By chinard in forum CJ YJ TJ and JK
    Last Post: 10-09-2003, 06:58 PM
  4. how to get more power at highway speeds
    By Sacredgroove in forum CJ YJ TJ and JK
    Last Post: 09-25-2003, 08:26 AM
  5. Cherokee stalls at highway speeds
    By Tug-n-pull in forum Cherokee, Commander, Wagoneer and Liberty
Tags for this Thread
