BostonJeep
So after i did my 3.5" suspension lift on my 95 YJ, and before installing my pitman arm, i got an allignment.
The only reason i did this was because i broke two pitman arm pullers trying to get it off and needed to wait to bring it to another shop before i could get that on. But i had it in a tire place to pass inspection so figured i'd get it done anyways. besides, the guy that did my alignment, said i could replace the pitman arm later without affecting the alignment "because it only goes on one way"..
But anyways, after the lift and before the alignment, my Steering wheel was about 90 degrees off from center, clockwise...., and after the alignment it was dead center again. I'm pretty sure he wasnt supposed to straighten it because when i finally got around to getting the new dropped pitman arm on it is now off by 90 degrees from center in the other direction.
My two questions are:
Will the dropped pitman arm affect my alignment?
Is it easy to center my steering wheel on my own, with out affecting allignment? If so, how?
