Have checked all fuses, and did not see any that were blown. Checked the ones in the cab under the drivers side, and under the hood on passengers side.
Happened while I was driving and radio just shut off. The engine light and the two side lights that go on when you open the doors are not working either. Even the alarm wont trigger when the doors are opened.
Any help would be much appreciated.
