pinion shaft removal question on dana 35 non c clip
pushead
This is on a 88 yj IL6 non clip dana 35. I removed the axle shafts and the center of the pumpkin. How do I get the pinion shaft to come out? I want to replace the inner and outer pinion bearing. THe outer one exploded.
Thanks
take the bearing caps off... and then there is nothing else holding it in
well.. that is for the carrier... then the pinion should slide right out if you have the yoke out
Had to take a punch and pound it in the center of the shaft where the little whole is from maching the shaft.
Does any one have the tork specs to put the pinion bolt back on?
