1995 YJ Idle Mystery
planetfall
4 cyl., fuel inj.
After my engine warms up, the idle increases beyond what it used to. It now idles around 1,500 rpm to over 2,000, depending if I just put it in neutral after downshifting... sometimes it will decrease a little. The throttle cable is not stuck, it does this with the air filter off, it idles fine after it's started, but after it warms up, whoah.
This just started a week or two ago, does anyone have an idea?
Thanks much! [addsig]
1043197
Check all of your vacuum hoses. I even had a bolt back out of the intake manifold after a couple years and the gasket busted and too much air was getting in. Caused a really high idle. Just get a flashlight and look ALL over the engine compartment for a hose that might not be in it's correct location.
[addsig]
