After installing the transfer case drop that came with my 4 inch lift, I noticed my valve covers hit the firewall.
Should I nit run the drop ?
Ive got a 304 in a 82 CJ7
I figured the driveline on a CJ was short enough you don't need a TC drop. Can you increase the length of the rear driveshaft and adjust your pinion angle up more instead? I really don't think you need the TC drop on a CJ7 at 4".
