Thread: Lockers
    Craig's Avatar
    Craig is offline Senior Member
    Sep 2002
    Vancouver, BC, Canada
    1,490
    I've had my 8.8" rearend sittin here for a while now and haven't got around to putting it in yet. Still have to put the gears in and I'm not doing that till I get a locker for it. I was planning on going with an ARB but they're so expensive. Just wondering about cable lockers. Are they available for an 8.8 and which ones are best? I definately don't want a full time locker and I don't want one of those ones that engauge and disengauge by themselves depending on torque. Has anyone here put a cable locker into their rearend? Is it difficult?
    laneiac's Avatar
    laneiac is offline Senior Member
    Aug 2003
    West Linn, OR
    1,193
    RE: Re: RE: Re: RE: Yep
    I assume your refering to an OX locker, those are mighty expensive too, cost will be around the same as an ARB. You could look into a Detroit Electrac, I do believe those are a little cheaper.
    currupt4130's Avatar
    currupt4130 is offline VT Hokie
    Jan 2004
    Blacksburg/Williamsburg VA
    2,573
    ive got a couple friends who run the ox, in a d35 and a d30, they both have terrible problems with the cable housing not being stiff enough to engage the locker. one of my friends has converted it to a pneumatic actuator which works really well. my one buddy who has it in his d30 also has an electrac in the back and he likes it a lot, works pretty well. other than that i dont kno what else to tell you besides ive seen trouble with the cables flexing
    06 VW (hardcore crawler)
    "The mountains are calling and I must go." -John Muir
    Jan 2004
    2,573
    RE: Lockers
    Sully's Avatar
    Sully is offline Senior Member
    Jan 2003
    Washington
    3,316
    My buddy's got a hard locking detroit in his 8.8. Never givin him any problems and he is pushing 35's.
    TwistedCU's Avatar
    TwistedCU is offline Senior Member
    Jun 2003
    Pennsylvania
    8,944
    RE: Paragon pics from this weekend
    Is it a daily driver? I'm assuming that's why you want a selectable locker. If driveability and cost are factors, why not look into a Detroit Truetrac? Great driveability but doesn't wear out like the stock limited slips.
  7. #7
    Craig's Avatar
    Sep 2002
    1,490
    I think I'll just postpone the intall of my rearend a little longer till I can afford the ARB's. Hoping to get a good tax return this year so that'll help.
  8. #8
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    I can put you in touch with a jeeper near me that has an e-locker in an 8.8, he seems to like it so far. If you want cheaper than an ARB you better look elsewhere than a cable locker.
  9. #9
    Craig's Avatar
    Sep 2002
    1,490
    RE: Re: SugaMamas
    What's an e-locker? Never heard of em.
  10. #10
    TwistedCU's Avatar
    Jun 2003
    Pennsylvania
    8,944
    how to upload more than one pic at a time?
    A selectable electric locker. The Detroit Electrac is a limited slip until you throw the switch, then acts as a full locker.
  11. #11
    88Wrangles's Avatar
    88Wrangles is offline Senior Member
    Nov 2003
    Eugene, Oregon
    2,785
    Most electric lockers (e-lockers) are just like an ARB, but they use an electrical signal to activate and de-activate them instead of the air pressure that ARB's rely on.
  12. #12
    Nov 2002
    Southern Illinois
    13,425
    RE: The death of Hunter S. Thompson
    And are thus more reliable
  13. #13
    88Wrangles's Avatar
    Nov 2003
    Eugene, Oregon
    2,785
    RE: Re: RE: Re: RE: 2006 or 07 Redesigned Wrangler
    yep. No air leaks, no need to buy a spendy compressor, or run air lines. And, it works just as good.
    And all the electrical connections are sealed from water.
