Replacing fuel injectors and regulator
joejeepny
RE: Re: RE: Re: RE: HAS ANYONE NOTICED RUBICON REAR BRAKES D
Has anyone replaced thier fuel injectors with the accel ones? Are they any better? Has anyone every replace the pressure regulator with an adjustable one. Will more pressure give better atomization improving hp and gas milage or will it make it run rich.
Is the RUBICON lifted compared to a stock tj.
Bump - No one touched this one. No fuel injection experts out there?
all i can tell you is if you change out injectors... MAKE SURE THERE ARE NO LEAKS!!!! i rushed a change out once and it was auto flambe' in the driveway when the car made it home... not technical advise but if they weep or leak at all... bad things happen... (o-rings, clean out the ports where they go... etc.. etc...)
as far as what is better, depends on the motor, application, what youre doing... and the regulator... check the pressure with a gauge (or install an inline one) to see what you have and go from there... for a stock motor the stock injectors are fine - if they have to be replaced.. let price be your guide - hear the OEM ones are about $75 each from the dealer... YIKES!
