    Greencuke's Avatar
    Greencuke is offline Senior Member
    Sep 2002
    bagdad
    412
    1045838
    im getting a whistling noise (could u guess) from the passenger door. i had a leak from my triangle window, so i thought that might be it and i sealed it, but it wasn't. if i opwn the big indow a little, the whistling gets less, and if i open it a lot, it goes away. i though it might me a cracked gasket, but theres non i can see of. does this sound like anythign to anyone? [addsig]
    you better run Terror! Im comming for you!
    jeeperwilly's Avatar
    jeeperwilly is offline Senior Member
    Oct 2002
    MN
    299
    1045845
    First off I'd just like to say, its a jeep it will never be completely sealed and will always have some sort of noise you can never explain. With that said, you might have a seal on the door that isn't completely sealing. What I would do is go to your local hardware store and find some selfstick 1/2 in. wide foam sealer. Take the sealer and run it along the upperjam where your door seals meet the top. I usaully do this for winter. If thats not your problem, try looking at the corners where your windshield corners and top meet. Good luck finding your whistle, Paul [addsig]
    '97 Slinky
    North Shore Wheelers
    www.nsw4x4.com
    Tug-n-pull's Avatar
    Tug-n-pull is offline Senior Member
    Oct 2002
    East Tennessee
    5,149
    1045847
    May be that you and your jeep are more alike than even you think, besides your ruged good looks and all you may both have air escaping from your not to well sealed upper units. lol Sorry just could not resist Dude, Tug[addsig]
    MORGSTER's Avatar
    MORGSTER is offline Senior Member
    Jan 1970
    Orange County, California
    272
    1045852
    Greencuke:
    Whistling noises from a Jeep are pretty normal. It could be anything from a bad door or window seal, window not all the way closed, to a door needing adjustment, and possibly the door just not shut all the way. (Don't laugh, it happens) If you really want to find it, get some duct tape, start putting a little along the noisy area and drive. Keep adding until you find the point of entry. Then figure out how to solve the problem. My hardtop doors were the cause of my whistling, adjusting the catch was the solution.
    In the past I have found out most problems on a Jeep are adjustments. or pilot error.[addsig]
    chinard's Avatar
    chinard is offline Senior Member
    Aug 2002
    Toronto
    268
    1045853
    Ummm...
    The radio antena on my CJ whistles like crazy...
    try looking at that too[addsig]
    \'82 CJ-7 - AMC 258 -
    Mods: Weber Carb, Borla Catback, Juicebox TFI, 31\" BFG AT, Powermaster 150a alternator, H4 headlights, blazer heater motor conversion, WORKING gas gauge.
    Now with 80% less rust!!!
