Tie-rod end
monkeyman
I have a very quick question- What side of the vehicle does the left hand (reverse) thread tie-rod end go on?
Thanks!
OK- Nobody in the world seems to know the answer to this question! I have looked at tie-rod installations on-line: Some folks say left hand thread goes on the passenger’s side others say left hand thread rod-end goes on the driver’s side????
Any input…
Thanks
I don't see how it could matter, as long as they are opposite on each end so you can adjust the alignment without disconnecting the ends.
It doesn't matter, unless your building a steering setup using differing types of TRE's and they are to be used on one end or the other.
