I just bought an 89yj with the 4.2L carbed. I am haveing trouble getting it to run properly.
It starts and warms up just fine, but when you get to normal op temp the problems start.
it seems to have an intermitant miss after it gets warm and then when braking it will even sometimes stall.
As you slowly give it gas while in park (and when driving) you can hear it studering.
I am at a complete loss.
i did check the basics, tune up, carb and intake air leaks (now fixed) ignition system is all but replaced. reset the timing numerous times but no success.
If there is any info you can help me with i would appreciate it.
Thanks,
Thanks,
