    jay79cj7's Avatar
    jay79cj7 is offline Senior Member
    Jun 2003
    Palatine, IL
    1,086
    Starting Problem
    My 79 CJ7 258 has refused to start twice now in the past two weeks. When I turn the key, I hear what I can best describe as a buzzing or fast clicking noise coming from the starter solenoid. The engine does not turn over at all. Both times this has happened I popped the hood, checked all the connections, etc, but found nothing wrong. The first time I took a wire straight from the + battery terminal to the solenoid and it engaged and the motor turned over. I then went and turned the key and it started. It didn't do it again for about 2 weeks until tonight when it nearly stranded me at my parents' house. I tried that same trick again, but no luck. My dad was convinced it was the battery so he gave me a jump, but no improvement. After a while of screwing around with it, I tried the key again and it started.
    Anybody deal with something like this before? I don't want to get stranded somewhere, but I don't want to just start replacing stuff and hope it doesn't happen again.
    Thanks
    jaymz77's Avatar
    jaymz77 is offline Member
    Mar 2006
    Portland, OR
    89
    Re: Starting Problem
    Almost 100% positive that it is your solenoid. They don't always go out all at once and usually start sticking before ending their life. If you have the trouble again just tap the solenoid with a mallet and it should break free. However I think a new solenoid/starter might be in the future.
    A good Jeep has no doors.....The best Jeep has no top or doors and is driven year round.
    jay79cj7's Avatar
    Jun 2003
    Palatine, IL
    1,086
    Thats my first guess, but I'm surprised because its pretty new. Only about 2.5 years old, and it still looks new. Not even any rust visible. I plan to swap it out, but given that this waited about 30-50 starts between episodes, I won't necessarily know that changing that fixed the problem right away. I want to make sure its the right fix so I don't get stranded somewhere!
    jaymz77's Avatar
    Mar 2006
    Portland, OR
    89
    You've checked all connections to the solenoid and all your grounds, including the block to chasis ground?
    TwistedCU's Avatar
    TwistedCU is offline Senior Member
    Jun 2003
    Pennsylvania
    8,944
    Can't you try to start it by bypassing the solenoid with a screwdriver? If it starts okay then you will know it is the solenoid.
    jay79cj7's Avatar
    Jun 2003
    Palatine, IL
    1,086
    Well, last night when I was trying to figure out what was going on, I jumped the solenoid terminals with a set of cables and it didn't do anything besides spark alot. Then I hooked one end of the cable to the starter terminal and then touched one to the + terminal; also nothing. This is when my dad was convinced the battery was dead and tried jumping it. I went back to jumping the + terminal to the solenoid starter signal terminal and it sparked and just barely moved the starter. This is when I went back and turned the key and it started. Being that I jumped the terminals of the solenoid, I don't think its just the solenoid. I hadn't thought of the block/chassis ground. I'll check that!
  7. #7
    larryboyCJ's Avatar
    larryboyCJ is offline Junior Member
    Jun 2006
    Greenville SC
    14
    my CJ had the same problem. me and my uncle changed the plugs, wires, distributor caps, and seliniods and it turns over fine now
  8. #8
    redrooster's Avatar
    redrooster is offline Senior Member
    Aug 2003
    2,775
    Since mine was a automatic transmission, I always carried an extra solenoid. They were only like $12 at Ghettozone.
    1622 Miles from Moab.
  9. #9
    Craig's Avatar
    Craig is offline Senior Member
    Sep 2002
    Vancouver, BC, Canada
    1,490
    Had a similiar problem before. It turned out that the + cable going from the battery to the starter was corroded underneath the sheilding. The cable looked good at both ends where the connections were but when I peeled back the sheilding the wire was almost corroded in half.
