LVRockCrawler
Okay... just went thru and R/R'd the entire ignition (cap/rotor/wires/coil/module) as my jeep decided it didnt want to take me to my destination twice in two days... (funny sight being towed home behind a 90 Accord = can be done tho!) anyway.. one problem i had b/4 this ordeal was hard starting when warmed up and allowed to sit for 5 min or so - thought it would go away w/the overhaul but still doing it - seems like the fuel is draining/boiling out of the carb when sitting and the engine spinning brings it back up - could this be a fuel pump issue (pos bad diaphram?) any feed back will be great - or if you need more info... otherwise she runs/idles better than ever... just hard starting when hot... miss my fuel injection... thanks!
