speeddemon651
Ok I can get my headers to barely fit, If I switch the holes I had the slave cylinder mounted in. The first picture you can see how close my header is to the passanger side rear spring mount.
http://i70.photobucket.com/albums/i8...1/CIMG1794.jpg
#1
I guess I have the wrong clutch Fork, my current one is too low, does anyone know which model Year and model FORK I need ? I believe the trans is a 176 ? The picture below is the current fork I have in and a picture of it in the truck. Do I have to pull my trans to get the fork out to swap it ?
http://i70.photobucket.com/albums/i8...1/CIMG1785.jpg
http://i70.photobucket.com/albums/i8...1/CIMG1801.jpg
#2 I have several wires and plugs that I'm not exactly sure what to send them to. On the solenoid LEFT side I have the battery and Alt Cables, the left top Post I was told it was the Ign. feed wires. Right side top Post Ign Mod. feed, and right lower Post starter Cable. I'm currently running a HEI and just need a power red/w stripe to power it, where should I pull it from ?
These are the current wires I have hanging
purple Long
Purple -has been cut to behind the carb
Brown
Black
Orange
Yellow
Blue
3 red wires
Red/white stripe large diameter
Red/white stripe small diameter
Please Help
http://i70.photobucket.com/albums/i8...1/CIMG1804.jpg
http://i70.photobucket.com/albums/i8...1/CIMG1803.jpg
http://i70.photobucket.com/albums/i8...1/CIMG1806.jpg
#1
purple Long
Brown
Black
Orange
Yellow
Blue
3 red wires
Please Help
