Slip yoke eliminator kit / CV driveshaft
freebird2
I recently installed the pro comp stage 2, 4inch suspension lift
Do you think I should install the SYE kit and a 16.5 CV driveshaft?
I was informed by the dealership not too.
Welcome to the Z.
How did they correct the rear driveshaft angle, lower the transfer case with spacers?
If you're not getting any driveline vibes, and the loss in ground clearance doesn't bother you, run it like it is. If you want to make the driveline stronger and get more clearance under the belly skid, install the SYE and CV driveshaft.
Tell us about your jeep, like year, model, drivetrain, etc.
I'm curious as to why the stealership told you not to install a SYE.
No good reason on why except they would not recommend it and they have never seen this done before. I want it done and have been told by many that this is the way to go if you raise your Jeep 4 inches or higher.
It's the 'correct way' of setting up the rear half of the drivetrain when you lift 3"-4" or higher. They haven't seen much if they haven't seen it done before. I install them all the time.
I'm surprised they didn't tell you they had the "Correct" parts to "Fix" the problem and that's why they said to not install the SYE. I've done alot of reading, especially on here, and a SYE is definantly the way to go. That is one of the first things I'll get for my future mods when I lift mine.
Do you need the slip yoke eliminator when you get a bigger CV driveshaft or can you just use the stock part? What is the exact reason you need the SYE?
The rear driveshaft is not a CV driveshaft, only the front.
And it's not a true 'CV' driveshaft, just commonly termed CV (constant velocity) when it's actually a 'double cardan' joint at the transfer case end of the front driveshaft, single cardan at the axle end.
When you lift a jeep, the distance between the rear axle and the transfer case becomes greater, requiring a longer driveshaft. The operating angle of the ujoint at each end of the rear driveshaft becomes greater, often at the max constant operating angle. Not good for ujoint longevity.
The SYE replaces the mainshaft and output housing in the transfer case for a much shorter output. The shorter output means a longer driveshaft can be used, thus resulting in less angle at the ujoints. The SYE also converts the slipyoke at the front end of the rear driveshaft to a fixed yoke at the transfer case. The splined slip section is then moved to the middle of the driveshaft. The fixed yoke allows a CV joint to be used.
With a SYE and CV driveshaft, you're required to point your rear axle pinion directly at the transfer case output. This is generally accomplished with adjustable upper control arms, so add that to the cost.
Check out Tom Woods Custom Drive Shafts Custom Driveshafts Specialist for more driveshaft tech from Tom Woods.
